Boxers en Motoren Service
Ottenhof Motoren Amsterdam
Motor Service Amersfoort
Mordamus Webhosting
Boek uw hotel / B&B / camping het via het forum: Ned - DuiHarz - Eifel - Fra - Oos - Alpen - Tsj - Bel - Lux - Eng - Ier - Pol - Den - Noo - Fin - Ita - Spa - Por - USA - Elders
BMW R1200 RT LC koplamp vervangen
Moderators: Walter, JOS WRSM, EileRT
Ruud Woudstra
Bijz: Full options 2014. Ebony metalic, BMW Nav VI
Ongelezen bericht door Ruud Woudstra » 16 nov 2017, 13:50
Net de RT LC aan het uitproberen en de oude RT met dubbele kolamp gaf mooi veel licht. Nu wil ik in de RT LC de Philips X-treme vision gaan monteren. Maar hoe doe je dit simpel, ik kan er niets over vinden. Je kunt wel de achterkant van de lamp zien maar of je dat dan ook eenvoudig kunt openen kan ik net niet zien.
Wie weet raad???
Alvast dank.
Grt, Ruud.
BMW K1200LT 2008
BMW K1200LT 1999
Garmin navigatie, BMW Nav6, en de Montana 610, CN2018.20, OMK 2017-18 W-Europa
Moderator
Moderator
Re: BMW R1200 RT LC koplamp vervangen
Ongelezen bericht door Bert M » 16 nov 2017, 14:40
Dit is wat de Amerikanen er over schrijven:
1. Put bike on centerstand.
2. Remove access cover by reaching up from underneath (lefty loosey).
3. Look in from behind handlebars with a flashlight to see the connector.
4. Adjust handlebars and reach in past the fork tubes and pull connector straight off...it should come off easily.
5. Look again to see the orientation of the spring clips. To release the bulb, you have to push them forward then toward the outside. You can do it with your finger. I wore a nitrile glove which gave me some grip on the spring. I found it easier to remove the starboard side clip first, and the port side clip second. (For some reason it's much harder to get the starboard clip off if you take the port side off first.)
6. Pull bulb straight out. Note orientation of tang (pointing up).
7. Insert new bulb with tang pointing up. I had to feel my way around to do this part, but it only took a minute or so. Remember not to touch the glass part with your hands. Confirm that the bulb is properly seated by looking in from the front of the headlight.
8. Put the spring clips back on. I did the starboard side first, port side second.
9. Push the connector back on.
10. Replace the access cover.
11. Start 'er up and confirm the new bulb works.
It took me the better part of an hour to get the procedure down to these steps. Now that I've done it once I could probably do it in 10 minutes.
Bron: www.BMWLT.com (BMW Luxury Touring)
Draag je het RT Forum een warm hart toe? Word dan nu Goldmember >>
Lemoi
CliniClowns actie 2017
Ongelezen bericht door Lemoi » 16 nov 2017, 19:47
de lijst van Bert klopt. Ik gebruik meestal even mijn mobiele telefoon om te kijken hoe die "veertjes" zitten. Dat is het meest lastige aan het verwisselen. Kap afdraaien van achter de lamp en connecto rloshalen gaat prima. Ook het monteren van deze gaat prima. Ook de lamp er dan uit halen en er een nieuwe inzetten gaat prima. Maar daartussen heb je die twee veertjes... Ik maak dan toch even een foto om te zien hoe ze zitten en dan op gevoel deze losmaken en dan weer vastmaken
Ruud Woudstra
Ongelezen bericht door Ruud Woudstra » 16 nov 2017, 20:29
Dank voor de beschrijving en tips. Ik ga het eens even uitproberen.
Grt, Ruud
BMW K1200LT 2008
BMW K1200LT 1999
Jos1200rt
Bijz: Vstream ruit, BMW topcase, Garmin Zumo 590, PR4
Ongelezen bericht door Jos1200rt » 20 nov 2017, 15:56
IK heb de ervaring dat vanwege de claxon ik weinig ruimte heb voor mn hand. De claxon draai ik daarom maar n beetje los of haal m, tijdelijk, helemaal los.
Succes
[groet] Jos
Lemoi
Ongelezen bericht door Lemoi » 21 nov 2017, 15:51
Jos1200rt schreef:
20 nov 2017, 15:56
Succes
[groet] Jos
ik doe het van voren en van onderen. Heb geen last van de toeter (heb ook een grotere toeter ipv het orgineel)
Mariecke
Bijz: 2005, Granit-grau, Topkoffer, Xenon
Ongelezen bericht door Mariecke » 25 nov 2017, 18:43
Het vervangen van de koplamp van de LC gaat op exact dezelfde wijze als bij de RT.
Enig verschil: het is er maar 1 en hij zit in het midden.
Als je 'm vanaf de voorzijde vervangt, is het een klusje van 2 minuten!
Succes! _004
Ruud Woudstra
Ongelezen bericht door Ruud Woudstra » 28 nov 2017, 10:49
Vandaag maar eens even aan de slag om de koplamp te vervangen.
- Losdraaien beschermkap is geen punt, kun je ook goed bij.
- Stekker lamp trek je er nu zo af.
- Bevestigingsclips is een ander verhaal, de eerste ging simpel maar de tweede wilde niet los, hiervoor een tooltje gemaakt, zie foto.
Hiermee kon ik vanaf de stuurkant het clipje eenvoudig los klikken. Stokje bamboo van rond 6 mm, hier even een gleufje in gezaagd.
- Lamp eruit, nieuwe erin.
- Nu ook de clips weer met het stokje gemonteerd, ging redelijk eenvoudig, en je kunt zien wat je doet. ( lengte sokje ca 40 cm rond 6 mm).
- Stekker er weer op, is even wat zoekwerk maar lukt wel.
Beschermkap er weer op en klaar.
Testen.. en lamp doet het. :D
Dank voor alle tips. Het is goed zelf te doen. 15 min werk.
Grt, Ruud.
BMW K1200LT 2008
BMW K1200LT 1999
Wie is er online
Gebruikers op dit forum: Geen geregistreerde gebruikers en 3 gasten
